ITR Vs D.C. 4-1 Header, What is better
Discussion in 'Engine Building' started by brc80, Dec 26, 2002.
  1. brc80
    brc80 Senior Member
    Southern California
    Hey guys i was just wondering what would be a better header to go with in my car, it will be a daily dirven car with a race here and there. After the header the only other mods i will be doing are cam gears and ctr cam shafts, unless you guys can think of anything else i need after that, thanks for the help
  2. E_SolSi
    the JDM ITR header is better than the DC copy of it
  3. S13Less
    S13Less Member
    San Mateo, CA
    Get the DC 4-1 header with the 2.5" collector. The JDM header is good, but when you slightly increase the size of the collector it's even better. I've seen dynos of this where the collector was increased by only 5mm and showed remarkable gains for such a small modification to the piping.
  4. E_SolSi
    quality of the DC compared to the JDM ITR is laughable... material isnt as good, welds arent as good, and the JDM ITR has a 2.5" collector the DC is a cheap copy of it
  5. brc80
    brc80 Senior Member
    Southern California
    Where will my gains be if i go with the itr header?
  6. E_SolSi
    mid to high RPM area .... both are the same design ... DC copied the JDM ITR for their header but the materials and construction is not as good so you wont get as much life out of the DC as you will with the JDM ITR... also with the JDM ITR you can keep the heat sheilds for a more stock (sleeper) look and you can get a skid plate to protect them from getting dented... these wont fit on the DC header
  7. brc80
    brc80 Senior Member
    Southern California
    Cool i really want to go for the sleeper look, no body kits, no wings, just light wheels and a lower stance, im trying to get as close to a jdm integra xsi as i can
  8. E_SolSi
    with the heat sheid and the skid plate this is what you will have on a JDM ITR header
    [​IMG] [​IMG]
  9. brc80
    brc80 Senior Member
    Southern California
    Very nice, what should expect to pay for itr header?
  10. E_SolSi
    http://www.alljdm.com has them for $375
    he also has the 2.5" gaskets for $25 and the heat sheilds for $60 the skid plate you get from http://www.fastlineperformance.com they have 2 designs of it for $40-$50 (well worth it... id rather buy another $50 skid plate than a $400 header) :)
  11. brc80
    brc80 Senior Member
    Southern California
    Tahnks for all the help so not only in this post, but in anyother post ive done you've been a great help. Have you owend a b16 before everything that you've told me has been spot in thanks.
  12. E_SolSi
    glad i could help... no B16's but i have a B18C/R going in this winter.... ive done a lot of research i guess (gotta love OCD) :)
  13. brc80
    brc80 Senior Member
    Southern California
    Are you local "So Cal"? Id like to see your ride
  14. E_SolSi
  15. phunky.buddha
    Dallas / Fort Worth, TX
    <-- Needs a skid plate on his header... rock on the highway 0wned the DC 4-1!
