JDM b-series transmission plus lsd (oil)
Discussion in 'General Tech and Maintenance' started by orsfry, May 12, 2005.
  1. orsfry
    orsfry Junior Member
    yea,
    so i got a JDM B-series transmission w/LSD (don't know the code off the top of my head) and i'm putting it into my 95 civic with the integ swap (original tranny blew last november) at any rate, does it need any special oil, or will the same motor oil from the engine do?
    thanks
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Honda MTF or GM Synchromesh.
  3. ludegirl
    ludegirl Senior Member
    Southern Cali
    A few of the local shops around here recommend using a straight 30 weight oil, I have used both this and honda MTF and, to my ablility to judge, they preform about equally.
    Is it an OEM lsd, I know some after market ones recommend an additive, not sure about the oem though.
  4. ripperbone
    ripperbone angry bear
    Oklahoma
    good stuff :thumbsup:
  5. ef9civicgen4
    ef9civicgen4 Senior Member
    Independence MO
    fuck GM, its like $12 a bottle. pensoil is the actual company that makes synchomesh for gm. so go to auto zone, and buy some pensoil synchromesh. its like $5 a bottle and its the exact same thing. oh, and it wont be with the other tranny fluids, its with the gear lube.
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    use regular 10W-30 motor oil. or synchromesh. I used honda MTF and I didnt like it.
