JDM B16a into 94 ex coupe
sleepercivic
JDM b16a into 94 ex coupe
Which fuel line do I use?
Stock Line from my car or 94-95 Del Sol DOHC vtec line?
thanx in advance
Which one, the one from the car to the motor, or the motor to the car? I used the cars to the motor, and the motors to the car, if that makes sense to you.
I'm a little confused
I need to which one to use that goes from the fuel filter on the firewall to the fuel rail on the engine?
thanx again
Ok, use the motors. I believe they are the same though, they are on the VX. :)
Originally posted by JDMilan@Jul 5 2003, 05:09 PM
They are actually different on motors, the B series are a little larger than the D.
Milan
Mine was the same. :huh: at least the fitting was.
I also used the same fuel line that was on my EG but I noticed that there was an actual difference. They are the same length and size from the outside but I noticed that B series equiped rides, the brass fitting that goes on top of the fuel filter where the fuel comes out and throught the line was internally larger in size, from a visual perspective.
Milan
