JDM B16A OBD1 BEST ECU? and Header?
Discussion in 'Civic and del Sol - EG and EK' started by B18BeK9, Feb 29, 2012.
  1. B18BeK9
    B18BeK9 New Member
    I am now installing a b16a in my ek.. i want a chipped ecu to get knock sensor and o2s disabled, the vtec starting @ 4500 and the fuel cutoff @ 9000rpm. I do want to know if there's a difference between a chipped p28 and a chipped p30..?
    Aslo.. I have 3 different headers.. : 1 stainless steel tri-y 2'' outlet. 1 stainless steel 4-1 2'' outlet and 1 dc sport ceramic coated 4-1 2.5'' outlet. I use a Yonaka exhaust line 2.5'' that has a restriction to 2'' to bolt on the front pipe..
    the dc sports.. are the nicest.. but ive heard that if I d'ont have a small restriction near the engine: ill loose power.. any infos about that...?
  2. B18BeK9
    B18BeK9 New Member
    The dc header was made for a b18c type r engine..
  3. B18BeK9
    B18BeK9 New Member
    I aslo want to know if it's rly possible to gain hp by chipping the ecu and if yes.. how?
  4. B18BeK9
    B18BeK9 New Member
    my b16 has new pistons, rods, and crank.. the intake is ported too. it gives 225psi per cylinder of compression
  5. B18BeK9
    B18BeK9 New Member
    everything is done alrdy thx anyway..
  6. truchoEG
    truchoEG New Member
    looking to find out...whats the best ECU for a b18b1 swap on a EG...and transmission wich 1 is recommended??
