JDM B20 for 3rd gen prelude
Discussion in 'HYBRID -> BA-BB /CA-CD' started by prelude2004, Sep 10, 2003.
Thread Status:
Not open for further replies.
  1. prelude2004
    prelude2004 Junior Member
    Apparently the JDM B20 has 160 hp, and, if the H22 swap proves too costly, I want the B20. Does anyone know where to find it? :shrug:
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    dude, JDM B20A5 does not have 160 HP- where the hell did you see that?
  3. prelude2004
    It is the B20A from the 86-89 JDM Accord; apparently it bolts into the Prelude
  4. racerx h23
    racerx h23 Member
    TN
    Well, $%&* me with a stick! Hes right!
    I've never seen or heard of this engine before and I wouldn't know where to start looking. From honda.jp's site the engines seem identical. Same bore, stroke and compression. Too bad they don't give an a5 or something at the end of the b20a. It came in the '85- '86. The '88 came with the a series and in '89 they went to the f20.
    To see for yourselves go here: http://www.honda.co.jp/HOT/ModelData/accor...-505/index.html
    Translator: http://world.altavista.com/
  5. spiffyguido
    spiffyguido Junior Member
    Alberta, Canada
    The B20A that you are referring to bolts directly into 2nd gen preludes. I don't think that the third gen engine bay is the same. Just something to keep in mind.
  6. prelude2004
    only one way to find out..... Does anyone know any other engines to swap into this Prelude?
  7. Slammed90Lude
    milford, PA
    what's PS mean as a power ratio? equivalent to HP??
  8. racerx h23
    racerx h23 Member
    TN
    spiffyguido: If he uses the 3g mounts it should bolt up the same. A b20a is a b20a is a b20a. At least thats my theory.
    prelude2004: See my responce on h-t.com.
    Slammed90Lude: 1hp= 1.1ps
  9. spiffyguido
    Alberta, Canada
    Not to diss, but I am positive these are not the same engines. I know this because I am currently preparing to get a B20A to put into my 2nd gen. I have to get it from Japan, because the ones in the 3rd gens don't fit.
    See here for more info on the B20A (not the same as B20A3 & B20A5 that came in 3rd gens). It's a wonderful engine. 160hp.
    http://3geez.com/showthread.php?threadid=86
    also here.
    http://3geez.com/showthread.php?threadid=5907
  10. mariowc
    mariowc Junior Member
    Littleton, CO
    First, dude, there is no JDM b20a5 engine. It would be a JDM b20a.
    Second, the 2nd gen Preludes in Japan featured a rare found b20* engine that was rated at 160hp. Very rare. Honda however switched over to a lower power engine (JDM b20a @ 140hp) for some unknown reason for the 88-91's. This rare b20a engine will NOT bolt up to a 3rd gen lude. Not happening.
    b20a = JDM 140hp
    b20a3 = USDM carb 100-something HP
    b20a5 = USDM 135hp
    b20a7 = EURO, 150hp
    There is one other I am missing, it might be the b20a2... I think that one is EURO too though.
  11. spiffyguido
    Alberta, Canada
  12. racerx h23
    racerx h23 Member
    TN
    Not taken as a diss, I'm just trying to understand this engine since its new to me.
    For the record, there is a b20a5. I checked the Helms.
    I still disagree about it fitting the 3g Lude tho. From looking at the Helms and the pics on links you posted and the pics someone on 3geez posted for me, it looks like the mount brakets on the engine and tranny would have to be changed to the 140hp b20 for it to fit the Lude. Other than that, the bolt locations look to be the same. In addition, I guess its this JDM Accords b20 3g Luders have been installing and not the b20 out of the JDM 3g Ludes like I previously thought since its the same 145hp I've heard from them. Till I have more detailed info, I stick to my theory.
  13. racerx h23
    racerx h23 Member
    TN
    After some more research and realizing that I think I've been chasing my tail, I've come to this conclusion. The importers I've talked to say that the JDM b20 with 145hp is a Prelude engine but I'm thinking differently now. I believe the engine you're talking about is the same engine 3g Luders have installed into their cars. You'll need to mix and match allot of things thats not normally needed on a typical swap. Go to the first site for a detailed description on how to get this b20 usdm friendly so you don't have to import stuff like the timing belt. The other three are 3g Lude sites. I know UT-34 and Daily Interlude from Team Interlude did a JDM b20 swap so they'll be better able to help you. If they didn't use that same Accord engine, post back cause I've got some other ideas that could help you to swap that engine into the 3g.
    http://www.teaminterlude.com/main.asp
    http://www.3rdgenprelude.com/p...x.php
    http://www.preludepower.com/phpBB2/portal.php
  14. daily interlude
    daily interlude Prelude Guru
    North of Atlanta
    Yes, the B20a from the 3g ludes and the B20a from 2g ludes and 3g accords are different. JDM B20a 3g lude engines are a direct swap for USDM 3g ludes.
    Please check out http://www.preludepower.com for more info
  15. LuDe&ReXrUnNiN
    LuDe&ReXrUnNiN Junior Member
    i have an 89 lude with the B20A motor it is rated at 160hp and 140lbs of torque extremely good motor, the only thing u have to change is the mounts on the b20a5 block and put them on the b20a, easy fix to ur problem. only problem with 88-91 ludes is not a whole lot of aftermarket support, but other than that the motor will rock most vtecs, if done correctly!
  16. LuDe&ReXrUnNiN
    and yes there is a B20A5 it came factory in my 89 2.0 si lude that motor is trash, just swap it out with the JDM B20A extremely good motor plenty of potential if u do the right things to it, will rock most vtecs stock! sohc vtecs really pose no threat to this motor, but dohc are a more rivaling adversary.
  17. daily interlude
    North of Atlanta
    How do you know it's 160hp? From what the JDM importer said (or where ever you got it)? If it bolts up to the 3g, it's not the 160 hp as the JDM b20a that's 160hp is for the 2g ludes and 3g accords (it bolts up to them...not the 3g lude).
    And the 3g lude JDM b20a is only like 2-3 more HP than your B20a5. if it feels stronger, then your b20a5 was already dying while you where driving it still...
  18. eludethis
    eludethis Junior Member
    yes there was a JDM b20 with 160hp...but. it was only for the 3g accord and honda vigors. the motors tilts foward. as opposed to yours which tilts towards the firewall. you cannot put this motor in your car. there will be oiling issues do to the TILT. yes it sucks that an accord got 160 and the lude only got 145. 150 fo si states model. but check this this out. H22 Mounts - Group Buy - Preludepower.com
    you'll want to get in on this.
  19. eludethis
    what's up daily. i just joined today.
  20. reikoshea
    Dallas, TX
    how bout we stop bringing old threads back from the dead....really guys.
Thread Status:
