I was never able to find actual JDM specs for compression, all I was able to do was find out what everyone else was running. My freshly rebuilt JDM h22a with 11:1 cr showed 260 psi across the board. There is a math equation that you can find that will give you exactly what your compression should be, but unfortunately I can't find it again. It is out there however, perhaps someone else can post up a link.
Those numbers are average for a USDM h22a, so if anything I'd say they're a little bit low for your engine, especially with only 50k on it. Not below service limits mind you, but somewhat low.
