JDM D15B SOHC VTEC What timing marks?
Kush2Slow
JDM D15B VTEC SOHC. I have heard so many different things about which marks I should use.
I need to know if I should line the pulley up like the Z1 using the two lines at 3 and 9 O clock with the arrows on the timing cover? Or do I need to time it like a Z6 using the 7 o clock mark?
cant remember on the marks, but you do use a z1 timing belt, so id assume go by the z1 marks as well.
