jdm itr into 95 gsr questions?
g3tegger95
I'm swapping my gsr motor into my friends ls and getting a jdm itr motor . I have some questions .
1. my car is obd1 and the place im buying the motor from said the itr swap is obd1 . Is this possible ?
2. If the wire's line up and everything what else do i need to complete the swap ?
Any wires to run or anything?
3. Will the itr exhaust manifold line up in my car ? I am using the stock piping until the after cat .
4. anything else ?
Thanks
1 -- no
2 -- if you use your harness then you wont have to worry about wiring
3 -- it should
4 -- i would think twice about ordering from a place that is telling me they have OBD-1 ITR engines
ok the place im ordering the motor from said they have obd1 itr motors $4500 for obd1 and obd2 is $300 extra . The site is www.hondahopup.com I found the swaps on www.groupbuycenter.com .
I have been searching through this bord and under engine references there is 96 b18c3 itr and it's says obd 1 or 2 . Could this be the motor they are selling me ?
