JDM ITR NOT STARTING
harryr34
Hi,
I wanted to know if anybody could help.
I need to get my car running.
The starter runs.
The fuel pump runs.
Thier is a spark.
but the car doesn't fire up. What else should i check on the car, I think the car had a clifford alarm and a vtec controller on it but the owner removed this, i have had a look at the wiring and it is all connected back up.
If anyone could tell me what else i should check?
Quoted post[/post]]
Hi,
The starter runs.
The fuel pump runs.
Thier is a spark.
Timing on the distributor?
Hi the car does have a spark at every cylinder but it still does not fire up??
Quoted post[/post]]
That's great. It still doesn't change the fact that your timing on the distibutor might be off a few degrees. The spark plugs will be working, but will be firing either too early or too late to turn the engine over. I'd check that first.
Quoted post[/post]]
Quoted post[/post]]
The person that i boughht it odd said that it was running, but he didn't try to start it after he removed the alarm and APEXI VAFC2. I am going to collect the APEXI VAFC2 from him today and wire it back up.
