jdm obd1 b16a into 00 civic ex swap questions???
Discussion in 'Civic and del Sol - EG and EK' started by redline870, Mar 19, 2012.
  1. redline870
    redline870 New Member
    im putting a jdm obd1 b16a into a 00 civic ex. im going to run a 00 civic si ecu, si axles, si shift linkage, si injectors, si rear mount, and del sol si ac bracket. as for wiring i know about the ckp bypass, and re-pining the connectors for the distributor and alternator. my questions are...
    which wire colors will i have to match up for the alternator?
    the distributor has a 2 plug connector where the original car has one small plug with fewer wires. which wires should be matched up for the distributor?
    is there anything else im missing?
