JDM tranny swap question
Discussion in 'HYBRID -> EG-EK / DC' started by 94RedSiGal, Mar 21, 2004.
  1. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    So... as B, E and Clayton know (and thanks to all of you!), I now have a JDM D-series tranny installed in my 1994 stock Si. The tranny code is S20. My speedo sensor doesn't work. So a VSS swap is in order. So what parts do I need to scrounge up? JDM or USM parts? Do I need to find a JDM plug to splice into my wiring harness? I can't have such a quick car and NOT have a working speedo.
    Help!
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Also without a working VSS the vtec won't kick in. Anyone should work, maybe the one from you old tranny.
  3. Bns773
    Bns773 Member
    Austin, Tx
    The VSS on my jdm b16 was jacked up after my swap so I repinned the plug. This still didn't work so I went to the junk yard and got a VSS of a Prelude. It's been working fine since. You might want to just pull it and bring it to the junk yard or parts store to get the right match. A USDM will work on it just fine try your old one.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    should be just plug and play.
  5. 94RedSiGal
    Massachusetts
    I went to the dealership and got a printout of an exploded view of the speedo sensor. Some stuff underneath needs to be swapped over.
  6. 94RedSiGal
    Massachusetts
    So this seems to be the stuff that needs to move over to the new tranny. It's just underneath the top plug assembly.
    Looks simple enough... but for some odd reason, Clayton persuaded me to LEAVE my old Si tranny down in his garage in CT. So I have to go back down there for the parts. *sigh*
