take it to autozone, aap, napa. with the length of the belt (or bring that belt with you) look for one that is the same size. dont worry about the belt being too wide. try to get one where the grooves are the same distance apart (ie if the belt is a inch wide and there is 3 grooves, find a belt that is like 2 inches wide with 6 grooves or 1.5" with 5grooves anything close) then take a razor blade and be very carefull, cut the extra grooves off. dont hack it or u will waste your money. we do this on my friends civic with a jrsc.
