Do you know were the conection is made: at the ecu, at the distributer harness? If it needs to be connected to the ecu you may have to use some ingenuity and modify your wiring harness. if not then it should be simple plug and play. From the looks of it on importparts.com, it's seems to be a simple install that would work on both obd0 and obd1.
