Right now I'm at 10psi using the Jackson Racing crank pulley and the 3.8(I believe) pulley. Another way you can get there is by using a CRV crank pulley. Finally, there's a company that makes a different stepper pulley (one on the alt.) that does the same.
i can see that this is going to be a pita to figure out what belts i need
i have several other pulleys besides the two that i mentioned before for the supercharger itself. im just not 100% sure where they go. the guy i got the kit from said it had everything there to make it any amount between 6 and 11 psi. ill take some pics and see if i can figure out whats what....
