patrickgies93
OK i am a new comer to honda swap, i currently drive a 96 eclipse gsx and i am converting into a honda man, much less maintaince then dsm. so anyways i notice a few things wrong right off the bat. instance...the radiator is in the trunk the fans are also in the truck along with the started. i am going to check out all of those things to see if they are good. install all of them back where they belong then i am going to see if the car will start. what else should i check on the car besides that
thanks in advance
pat
thanks in advance
pat
