just bought engine: need help evaluating it.
Discussion in 'Engine Building' started by blase, Sep 23, 2003.
  1. blase
    blase Junior Member
    Hey,
    I blew up my racing engine (and 2 years of my life) and I'm swapping in an old JDM b16a. I have 2 issues which I'd like some help with:
    1. When the engine showed up, it had some obvious signs of sitting outdoors. There was a termite nest in the exhaust manifold. The valve cover had been pulled just before shipping, and when I got it, there was an inch of oil/mud in each of the spark plug holes. I pulled each plug, hooked the starter to a battery and tested the compression. I got 90, 190, 120, 90 with cylinders 1 and 4 taking a while to reach max compression. I've never built a bottom end before, but I know that that's not good. I'm wondering if maybe while it sat outside a termite nest built itself inside the engine. It might explain the mud-oil. Or is this just a bad block?
    2. Regardless of whether the block is good or not, it came with an electronic shift auto tranny. Since my left leg is still screwed up from the old racing clutch, I don't mind dropping to an auto tranny, as long as I can wire in paddle shifters. The guy who sold it to me gave me the tranny computer from a 99 prelude, along with the shift console. I took his word that it would work, but now I'm not as sure. Does anyone know if I can use a JDM b16a1 auto tranny in an OBD1 integra controlled by a 99 prelude tranny computer?
    Any help you can offer is GREATLY appreciated.
    Thank,
    Blase
  2. Loco Honkey
    Loco Honkey Banned
    Wow... Well, I could get into it, but in a nutshell, get your money back!
  3. blase
    blase Junior Member
    Would you mind getting into it?
    I'm going to try to get my money back, but if that doesn't work, I'd like to know where I stand.
    Specifically, do you know if I can pull off this auto tranny deal? And do you suspect anything more than bad rings?
    Thanks for your help,
    Blase
  4. brc80
    brc80 Senior Member
    Southern California
    1. What did you used to race?
    2. What is your level of mechanical ability?
    3. Get money back.
  5. blase
    blase Junior Member
    I spoke with the guy who sold me the engine, and he explained that because the engine had been sitting for 4 years, the rings and valves needed to seat, and a cold compression test wouldn't show anything more than a bad cylinder. He told me to pour a quarter of a quart into each cylinder with the plugs out and turn it over 30 times. This seems to make sense to me. Anyone agree/disagree?
  6. kingwilly
    kingwilly Senior Member
    arizona
    your probably gonna need to replace the head gasket,after that give it a tune-up and then i would look for a manual tranny for it..good luck..o ya get the correct ecu..
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    what a fucking calamity.
    what kind of car is this going into?
