just got a del sol
Discussion in 'HYBRID -> EG-EK / DC' started by jdmlovingcrx, Jul 10, 2004.
  1. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    well i dont know much about the del sol its self i am having trouble with locating parts. Do EG parts work on a del sol?like exhaust and suspension stuff? What about mounts; do eg mounts work in there when going from d to b series. I need help befor i start.
  2. SnailOnARampage
    SnailOnARampage Senior Member
    Utah
    It really depends on what model you have, but here are the basics (trust me i know...i am on my 5th del sol)
    S models share the same engine/trans/axles/brakes/suspension parts with the 92-95 civic dx (the shocks and springs will fit but they are not as stiff as del sol's)
    Si models share the same engine with the civic EX, but they have rear disc brakes, which are the same as what is on any 94-01 integra, or 92-95 civic si.
    VTEC models have a suspension almost identical to the integra (the only difference being a 1 mm larger rear sway bar, and the emergency brake cables arent the right length.
    As far as the body panels and interior parts go, they are all unique to the del sol, and can be a little harder to find.
    If you are going from a D to a B series, you will just need to use the integra motor mounts. You will need to locate a del sol VTEC shift linkage, or modify an integra linkage. I dont recommend modifying the linkage unless you know what your doing though. The linkage that I modified turned out like a stock del sol VTEC linkage, but it took me 3 or 4 hours and I had to cut and weld a couple of times.
    The exhaust is fairly similar to an integra or civic, but some minor modification needs to be done in order to get it to fit (cut and rewelded in one or 2 places)
  3. vpSPOONsol
    vpSPOONsol Senior Member
    mildenhall village, england
    with a del sol you have access to cheap common parts, but a not so common car
  4. CRX2NR18
    CRX2NR18 Senior Member
    BOOO!! eddie, u shoulda kept the rex, that bitch was fast for what it was
  5. toyz51
    toyz51 Member
    The engine bay is identical to a 92-95 Civic besides the fact that the sol has a different shift linkage (longer) Suspension parts are interchangable with the 5th gen and 94-01 Integras. Exhaust is different than a hatch or a coupe and only a few companies make a prefab catback for the car.
  6. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    thanks this has been a big help...a kid down the street from me has a wrecked vtec model so i am hoping to get his b16 and well complete drop out out of the car!
    i was also wondering about the clear targa and how to get one...i know they were limited and an aftermarket honda instaulled part....i want to lighten this bitch up so what carbon fiber is avalible
