Just installed AEBS Intake mani
Discussion in 'General Tech and Maintenance' started by 97SIRTN, Jun 14, 2005.
  1. 97SIRTN
    97SIRTN Member
    Just got the "Typhoon Power Plus" intake mani from AEBS/whoever, and I was wondering how to test for leaks around the intake gasket.
    Could I turn the car on and spray the area water/some mixture and look for air bubbles?
    What could I do?
  2. E_SolSi
    the leaks will be sucking air in, so they wont bubble
    use something like brake cleaner and spray it around the whole gasket area while the car is idling
    if you hear the engine suddenly bog down then you have a leak
