Just noticed something...
Discussion in 'General Tech and Maintenance' started by jamesA, Jul 6, 2004.
  1. jamesA
    I'm kinda confused, i dunno. I was just looking at the engine reference section and I noticed something...
    B16A 1595 168@7800 116@7300 10.4:1 81 77.4 dohc yes 2 1996-2000 Civic VTi
    B16A2 1595 160@7600 111@7000 10.4:1 81 77.4 dohc yes 2 1999-2000 Civic Si
    If the bore/stroke/displacement are the same, how are the power levels different even if only by that 8 hp/5 ft lbs? Would it be because the VTi has (I'm assuming) a slightly higher lift vtec lobe on it's camshafts? :unsure:
  2. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    piston dome size is a little different.
    and yeah vtecsir1, you're right the compression ratio is a little different also which is most likely created by the difference in the dome size of the pistons.
  3. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
  4. jamesA
    so it is 10.2:1 compression on the a2...? <_<
  5. NotUrAverage_Si
    yup.
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  7. E_SolSi
    isnt the cam profile slightly different as well??
  8. jamesA
    that's what I was asking. :)
