K24 In '02 Civic Or Rsx
Discussion in 'HYBRID -> EP / DC5' started by cockstronghalfablocklong, Feb 15, 2003.
  1. cockstronghalfablocklong
    cockstronghalfablocklong Member
    Wilmington, DE
    has it been done? Is anybody working on it?
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you will need hasport, http://www.hasport.com/ mounts for the civic and stock mounts for the RSX... it is really only worth it in the RSX if you plan on putting an RSX head on the k24 block, and using the RSX tranny... The civic it is deffinately worth doing...
  3. ekPhred
    ekPhred Senior Member
    what car does the k24 come out of? just want to know for future reference.
  4. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    The new CRV
  5. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    and element
  6. cockstronghalfablocklong
    Wilmington, DE
  7. ekPhred
    thanx for clearing that up.
  8. MR. EG
    MR. EG Member
    it comes from crv's element's accords and some new car called the acura tsx. the tsx is going to be a good platform to build on. it is a 2.4 liter with 200 hp. thaqt is a whole lot of torque and hp starting out with.
  9. asmallsol
    The TSX is the real version of the Accord. In Europe, they list it as the accord but since it is under the acura name plate, they will tack on an extra 2k for "luxery (sp) accomidations." Looks so much better than the new accord. 200 hp will not be that impressive because it is a pretty heavy car.
  10. cockstronghalfablocklong
    Wilmington, DE
    yea, but if you swap that into a 2700lb civic si......
  11. MR. EG
    MR. EG Member
    a small sol said:
    "The TSX is the real version of the Accord. In Europe, they list it as the accord but since it is under the acura name plate, they will tack on an extra 2k for "luxery (sp) accomidations." Looks so much better than the new accord. 200 hp will not be that impressive because it is a pretty heavy car."
    I wasn't talking about the car, i was talking about the motor. i know that the car will be heavy as shit.
  12. sicsol2000
    sicsol2000 Junior Member
    Area 51 put a JDM CTR K series in a 5th gen hatch and it ran 13.8@100+mph it's first run.
    I've also heard the S2000 head will go on the K series bottom ends.
    K24 block with S2K head :worthy:
  13. Domeskilla
    Fort Wayne, IN
    Eh.. i was thinking of this.. k20 block, k24 crank, s2k head, etc.etc. not letting my thoughts COMPLETELY out. :p
  14. turbinedzc
    turbinedzc Member
    Too bad there is not a TSX Type S. Would probally be around 220HP
