Kaaz, oem, quaife LSD's...pros and cons
Discussion in 'General Tech and Maintenance' started by BigBoy, Dec 22, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    What are the main differences and advantages and disadvantages of each?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Kaaz is a clutch pack style. They are great for road racing, however, they are not just an install and forget about it peice. With clutch pack styles, they need to be adjusted/rebuilt every so often. If you have the time and ablity, these are probally your best choice.
    Gear types like the quaife are put in and practically forget about them, and the quaife comes with a life time warrente. however they are not as good as the kaaz LSD because when it sends power to the wheel that is not spining, sometimes it will go overboard and send too much power to that wheel causing that one to start to loose traction.
    OEM units are a non adjustable clutch pack that are not as bullet proof as the quaife, however its cheaper.
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    I thought OEM were torsion type?
    I love my ATS clutch type. But as asmallsol said they do need to be serviced often. Making U-turns in the car is not fun either.
  4. BigBoy
    cali 818
    so kaaz and oem are the same type? As far as adjusting the kaaz, approx how long before the rebuild?
  5. B16
    yay area, CA
    ~15,000 miles for kaaz
    I'm 99% sure the OEM is NOT clutch type
  6. phunky.buddha
    Dallas / Fort Worth, TX
    I think the older cable clutch transmissions used clutch pack LSDs- I know that my ZC transmission had one. The hydraulic clutch transmissions used Torsen/helical LSDs like the Quaifes.
  7. asmallsol
    ah my bad
  8. E_SolSi
    :werd:
  9. BigBoy
    cali 818
    maybe ill get a quaife...but dont have money =(
