Keeping Rotors Clean
Discussion in 'Wheels / Suspension / Tires / Brakes' started by ludeconduct, Jan 28, 2003.
  1. ludeconduct
    ludeconduct Senior Member
    Near Sac CA
    I'm finally getting a set of rims for my car that will show off my rotors. Unfortunatly there is some rust on the surfaces that don't get touched by the pads. 1. How do I get this off? 2. How do I keep it off? TIA, J
  2. eyesonlybob
    eyesonlybob Senior Member
    i was wondering the same thing, i plan on just getting new sloted ones, then there better and clean.
  3. chris
    chris Senior Member
    nihon
    use wd40! j/k u can just take sandpaper to the rotor and take the rust off
  4. E_SolSi
    get ceramic rotors ... ceramic = no rust :)
  5. ludeconduct
    Near Sac CA
    Ok, so sandpaper will clean the. What about using high temp paint on the un-touched surfaces? Thats about the only way I can think of to keep them clean of rust. NE one see possible problems with that?
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Next time you buy rotors, buy some stainless steel ones. I think EBC was selling some and had right on the advertisement "wont rust"
  7. ludeconduct
    Near Sac CA
    Mine are supposed to be stainless steal, and I only got the 5,000 miles ago.
  8. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    i just got new rotors too, brake cleen took it right off. dont paint your rotors though man. thats crazy. as for keeping the rust off go w/ ceramic
  9. BigJ
    yeah my buddy came around a set of brembo front rotors for a civic for only 80 from a shop. a little difference in stopping from brake fade but nothing drastic and dont' rust at all.
  10. sportlinecrx
    sportlinecrx Banned
    i assume you are talking about the rotor's hubs which are usually hidden by the center of the wheel, but can be seen from an angle. you should be able to paint those without causing any problems. there are paint products, like some primers, that are designed to stop rust. check pep boys. i've seen them there. then just finish them off with some brake caliper paint or high temp paint.
  11. wildbillhatchbac
    wildbillhatchbac the OG VIP
    IMO brakes are to stop your car . . . not to look all pretty . .. ok i'm done . .. peace
  12. AlphaSonicB20
    AlphaSonicB20 Junior Member
    Where the Hadji's Live
