Keyless Entry/Trunk
Discussion in 'Car Audio / Security / Electronic Accessories' started by CrewDelSol, Jul 24, 2003.
  1. CrewDelSol
    CrewDelSol Member
    Tallahassee, Fl
    I just bought a Keyless entry kit, and I was sorting through the wiring and I noticed that with it I got a trunk release button with my trunk releaser. Only problem is the way the wiring goes it looks like I can only use one, either the button or the remote. Because only one wire runs out of the trunk relay to either connect to the remote or button. I figured if i wired both in, neither would work. So anyone ever done or tryed somethin like this. Or do I need to run a second wire out of the relay into button? And no I don't know much about electronics so don't use any words bigger than positive, negative, or ground.
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ya wire both in it only actuates when 12v+ is put through it so you can hook up both
  3. donnieS
    donnieS Junior Member
    What kind of car/year are you installing it into and what brand module is it?
