Knock sensor on D16z6
Discussion in 'Engine Building' started by Argentinakidd, May 13, 2018.
  1. Argentinakidd
    Argentinakidd New Member
    hello everyone!
    So i recently purchased a 96 coupe with a bad d16y8. The head is still good, which im still going to use. A buddy has a cheap z6 block he can give me. Of course z6 has no knock sensor, and the ecu is going to look for one. This car needs to pass state emissions. So my question is: what are ways i can add a knock sensor to the z6 block??? I was thinking of jb welding a nut to the block and putting the ks there?? Any ideas/help would be greatly appreciated!:)
  2. Argentinakidd
    Sorry if this thread is in the incorrect section, first time posting.
  3. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    No it will not work , sorry but going to have to find a obd2 longblock to work correctly, even if could tap another hole for the sensor unless in exact location and depth etc (not going to happen) the sensor will read alot more noise than needed and try and make adjustments
  4. TurboMirage
    in the mitsu world, we would use an empty boss in the center of the motor and bolt the knock sensor to it...
  5. Briansol
    If emissions aren't an issue, convert the car to obd1 with a p28 and jumper. If they do an obd2 plug scan, that obviously won't work.
    but if they do a tail pipe sniffer, it would
    dilbeckskate and TurboMirage like this.
  6. Argentinakidd
    What about the spot on the back of the z6 block to drain the coolant?
  7. Argentinakidd
    Yes emissions is an issue. I live in a city that does emissions.
  8. dilbeckskate
    Kennesaw Ga
    NO WILL NOT WORK JUST STOP AND GET THE RIGHT MOTOR - end of discussion ....
    Argentinakidd likes this.
  9. Briansol
    Getting the correct block is the right solution.
    there are electronic ways to emulate a good knock signal, though. this guy tried, not sure if it was successful
    http://hondaswap.com/threads/knock-sensor-bypass.516726/
    ultimately, a y8 block is worth like $50 so it's probably cheaper to just buy the right block
  10. TurboMirage
    Well honestly cars survived fine without a knock sensor for a long time but it is helpful in its own right...
  11. dilbeckskate
    Kennesaw Ga
    Obd2 a/b use the knock sensor to advance timing WOT until it sees knock then backs off unlike pre obd/0
    TurboMirage likes this.
  12. dilbeckskate
    Kennesaw Ga
  13. Argentinakidd
    Yeah i just ended up getting a whole new y8 with trans and linkage included for 300 and it only had 130k. Like i said, i needed it to pass emissions so i didnt really want to experiment and waste time and money for the CEL to still be on. Thank you everyone for your input!
