Kseries motor swap: Do I need to remove the dashboard in a 2002 Civiv
Discussion in 'Body / Exterior / Interior / Cosmetics' started by rcaca0, Feb 1, 2014.
  1. rcaca0
    rcaca0 New Member
    Quick Question. I am thinking about doing a K series engine swap in my 2002 Honda Civic Ex coupe. I noticed on the internet and talking to a few people that I may need to remove my dashboard. Even the video from Hybrid Racing talks about removing the dashboard (it's for an older Honda but I still don't get it). Is this true? If it is, why do I need to remove the dashboard? Is there an easier way?
    Thanks,
    R
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I've never done one, but I'm guessing it's to route the cables and box for the shifter since the K uses a cable shifter box.
  3. rcaca0
    rcaca0 New Member
    For the shifter box, I just need to remove the center console. Is there something I am missing for the K series shifter box? I am thinking I just need to remove the ECU and replace it with the new one and the new wire harness which I think just connects the interior wire harness with the ECU. That leaves the exterior harness. Does anybody know what I need to do to remove the old one and replace it with a new one? Is there anything else that I may be missing?
    Just in case someone is looking for how to remove the ECU I found a pretty decent set of instructions here: http://www.civicforums.com/forums/3...s-fix-forum/293259-how-do-you-remove-ecu.html
    For a dashboard, I found: http://www.civicforums.com/forums/117-interior/323192-diy-dash-removal-01-civic.html
    Thanks again,
    R
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i have not done one either, but i have removed a dash in a 2001 civic, and the 7th gen is very easy to remove and put back if you do indeed have to.
  5. rcaca0
    rcaca0 New Member
    I purchased the civic manual and it looks as if there is a grommet that I pull the harness out of. I am attaching a pic of the instructions. Once I know for sure, I will post how I took it out.
  6. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    I do not believe you need to remove the dash. My older Honda (1992) didn't need it when I swapped a K
    Contact Hybrid Racing by phone and/or check out k20a.org.
  7. CAFROG
    NOR-CAL
