OK im not sure if this is the right section, i think it would be because it kinda is Purchasing related matter. ok i have a 1989 Honda CRX FULLY STOCK I NEED LABOR WORK DONE ON!!!! - I have a 94-01 Integra DASHBOARD I WANT PUT IN A CRX!!!! - I want my front end of the CRX changed to a 92-95 FRONT ENDS!!! name your price, i have all parts and tools just need a guy that can do the job!!! let me know asap thanks!!!
um....do you mean 94-01 cluster you want to install? As far as the front end, somebody correct me if i'm wrong but the only mods you can do with the fron end is to the SiR, assuming that your crx isn't. The 2nd Gen crx (that you have) only ran from 89-91, then the 3rd gen was the del sol (93-i forgot).Unless you do the integra front end swap which is a whole other can of worms....(foolish too if you ask me) Integras ran 90-93(da) then 94-01. 92-95 indicates a civic eg. You need to explain yourself a lil more buddy.
yes i know all the yrs it went... ok let me try again... i want my front end changed to 92-95 Honda Civic Hatchback EG style... which i have seen done before i just cant find any body around in IL to do it for me. no i dont mean 94-01 cluster i mean 94-01 Acura Integra DASHBOARD into a Honda CRX
