last question befor i order my turbo and start this build!
Discussion in 'Forced Induction' started by r1paniccia, Oct 6, 2011.
  1. r1paniccia
    r1paniccia New Member
    ok iam ready to order my turbo today, just have a few last questions here are my goals again
    this spring approx-250hp
    next spring 400 on fully built block.
    i want to use the same turbo when the block is built i do not want to have to buy another one!
    i decided turbonetics bc of there warranty ,they seem to have a good rep, good cust service, parts are easily available threw them
    talked to turbonetics yesterday and they recomend i use a t3/t40E 50 trim .63 A/R what do you guys think?? sound right for a ending goal of 400hp? will the .63 A/R give me a decent spool? and the last question is should i order it in a 4 or 5 bolt down pipe flange???? thanks for all of your help guys
  2. 98EkSi
    98EkSi New Member
    LOL your goals are the same as mine only I want 280-300 out of my stock Ls Vtec before I build an new block. I also am looking at a To4e .50-.57 trim .63 AR. It will be a good turbo for your goals and will make 400whp if you get the larger .57 or .60 trim. Boost will come in around 3000-3800rpms, a little laggy but you dont want to make boost down low, you will spin tires. As for the down pipe 4 or 5 bolts will work just a different design, pick one.
