leaking civic??
squeals
Member
so i noticed some moisture in my carpet one day on the floor board of my civic hatchback on the passenger side. i pulled up the carpet and there's a crack in that tar type stuff that is allowing moisture to come up through the floor boards. is this a serious problem? what could i use to cover the cracks?
the tar type stuff is not ment to keep moisture out. it's sound deadening material. jack up the car and look in that area where u see the leak, look for a crack or soemthing that would let water in. than spray some undercoating on it for quick fix. or waterproof caulk it.
thanks a lot!! i'll def put in on a lift later and check it out
