unbolt it?
You have to take the lower part of the exhaust manifold off, or if you have a 1 peice header, you must take off the whole header. Then take off all the bolts and any brackets that are in the way and take if off.
remember to drain the oil before you start. There will still be oil in the pan so dont spill it. Get a helms because your going to need the trq specs.
