locashracing.com ????
Discussion in 'HYBRID -> BA-BB /CA-CD' started by TNaccord, Jan 11, 2007.
  1. TNaccord
    TNaccord New Member
    Anybody ever use there products?
    If I was to buy the additional Add-In Vtec Harness:
    Locash Racing Online Circus
    And there OBD2-OBD1 ECU Jumper Harness:
    This is for a H22A in a 96 Accord LX. What else would be needed to perform the swap?
  2. TNaccord
    TNaccord New Member
    Anybody on H22A in 96 Accord?
    Would it be simpler to just do a OBD2 H22A Swap for a 96 Newer Prelude?
  3. brownkobe8
    brownkobe8 New Member
    i was thinking bout that gettin h22a obd 2 but i couldn't find them at all.
    I found the type S h22 which gives around 220hp thats obd2 but i kept hearin that you have to spend time workin on it cuz of the immobolizer or something like that
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Go to rywire.com for your wiring needs they are the best.
  5. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    the general rule is to buy a motor the same year as your car...at least same obd's. it makes wiring much easier and keeps you from having complex compounding problems
  6. powerdriverh22
    spfld, mo
    yes get an obdII motor unless you want to tackle the wiring issues that come along with swapping to obdI
  7. Taco15
    Tallahassee Fl
    i have the locash racing obd0 to 1 conversion harness. its really simple. i would use them again. Directions are really simple and easy to read/follow.
    that is all............
  8. brownkobe8
    My bad USDM have the immobolizer.
    I found this place that a buddy of mine bought the engine from torontojdm.com
    They carry the OBD 2a h22 pretty cheap.
  9. pissedoffsol
    they are a sponsor here... check their listing in the marketplace :)
  10. TeamUrbanChaos
    TeamUrbanChaos Certified H22 Super-tech
    Home Of ThE LoSt Towers
