lock problem with honda integra
Discussion in 'Integra' started by viGeflafed, Jan 17, 2013.
  1. viGeflafed
    viGeflafed New Member
    hey i have problem with my Honda integra 2002. it's driver side lock is not working properly but other rest of the doors working fine. some times it becomes impossible to unlock or lock the door. i'm badly frustrated with it. if anybody knows about any best locksmith plzzz suggest me from here
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Have you tried oiling it? Also try to take the door panel off to see if anything is broken or loose. Try to lube moving parts.
    Your question is very vague, does the lock act up when you are unlocking it from the outside, the inside, with your fob?
  3. E_SolSi
    :werd:
    also any noise
    grinding sounds? actuator sound stuck? nothing at all?
