for some reason i engine is low on oil there are not leaks it does not smoke
so i dont have no idea where the oil is going i have to add some to keep it full could it be a head gasket? any suggestion
Compression test the thing. Chances are you are slowly burning it through worn piston rings. trust me you have to be burning a lot of oil to see it out the back while driving. How quickly are you losing oil?
