Ls 5th Gear
Discussion in 'General Tech and Maintenance' started by mical0259, Apr 18, 2003.
  1. mical0259
    mical0259 Junior Member
    im getting an LS 5th gear synchro and putting it in my b16 tranny for obvious reasons. how do i do this and should i even bother doing it myself or take it to the pros? has anyone on this board done it and if you have how did you like it? also if you know any tech articles on tranny disassembly i would appreciate them. thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    get a helms manual ... and good luck. the b series trannys are a difficult thing to master. if you can get it for a good price, i'd say have someone do it for you.
    i am also planning on the LS 5th gear for my ITR tranny
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If it is a cable tranny, they are not too difficult if you are mechanically inclined and you have a helms. I have never been in a hydro tranny.
  4. solblu
    solblu Senior Member
    Ricer
    Where are you? It's a worthwhile mod if you spend a lot of time on the highway. If not I wouldn't recomend it. With a B16 you won't have much acceleration in 5th. If you can't afford to be down for a while get someone tha knows what they are doing to do it.
  5. 5genracer
    5genracer Senior Member
    Frozen north - ND
    I just put all new synchros and a couple of gears in my hydro GSR tranny, and it was pretty easy for the most part.
    Here are some of the things you will need:
    good manual
    large bench to lay everything out on
    hydraulic press
    bearing puller to get some of the gears/bearings off of the mainshaft and countershaft
    torque wrench
    feeler guage to measure the synchro to shift fork clearance
    A couple of things to keep in mind: While you have the case off of the tranny, look closely at the dog teeth on the gears. My synchros were to the point that the teeth on the gears were worn down and the gear had to be replaced. Also, make sure that you don't put anything on upside down - some of the differences are very small between upside down and right side up. One more thing, if you have to change any of the bearings in the tranny, make sure to check the clearance according to the manual and shim the case accordingly. Good luck.
    BTW, if you need help, i have an OEM manual that I might be able to photocopy and mail to you. Let me know.
  6. lsvtec
    Where did you get new synchros for the GSR tranny?
  7. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    basically get someone who knows what they are doing to do it for you, unless your interested in being a tranny master.
    heh
  8. mical0259
    im getting them from a guy who has a LS tranny with a bad 3rd gear. im sure you can get them from honda/acura, not sure about price tho.
  9. 5genracer
    Frozen north - ND
    I got the gsr gear (only third was bad) from my honda dealer. I also used 99-00 Civic Si synchros. All totaled, it was around $650 I think. I know that a new tranny is not to much more expensive than this, but who knows the condition that one is in.
