LS aftmkt rods + ITR pistons
Discussion in 'Engine Building' started by supafly90, Aug 24, 2006.
  1. supafly90
    supafly90 Junior Member
    What is the method to making the type R pistons fit the LS style rods? is it worth the hassle? I cant find and used b16 pistons for a decent price in my budget, but I can get some ITRs.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    most aftermarket rods use a floating style pin (pin is free in the rod and held into the pistons with snap rings at each end) - the stock type pistons are not compatible with aftermarket rods because they use a pressed in pin, which is pressed into the rod and floats in the piston
  3. Taco15
    Tallahassee Fl
    how much do you want to spend? I have p30 pistons on pr3 rods. I'll let go for 150. I know k2kevin was selling itr pistons rods AND gsr rods for a good deal. yu might to take a look. Just throwing it out for ya.
