INJEN78
HS LEGEND
no i the crx rear bracket has 3 bolts that connect to the block..i need a da rear bracket/..That's the b18b motor, not the b18a1. You need to use the rear mount from the CRX, that should fit properly. As far as the front goes, drilling is definitely the way to go.
You'll also have to hammer in the driver's side of the engine bay a little (don't go killing it now) so the ... was it alternator? ... doesn't rub. I had to pull my b18 out four times to get it right, the last time was to paint the spot that I hammered so it wouldn't rust.
and i already have the motor in..just waiting on my rear bracket...
