LS conversion to type r
Discussion in 'HYBRID -> EG-EK / DC' started by roach009, Nov 13, 2002.
  1. roach009
    roach009 Member
    I can i put type r parts like pistons into a ls engine and what other parts should i put to get the most results on the ls engine.
  2. pissedoffsol
    you other thread you are tlaking boost...
    boost + ITR parts = backwards
    make up your mind.... NA or Boost
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    No, the ITR pistons will not fit the LS rods without modification. The ITR rods will not fit the LS crank period. ITR cams are VTEC, LS is not. You can use the flywheel.
