LS ecm
Discussion in 'HYBRID -> ED-EF / DA' started by racintweek, Mar 13, 2004.
  1. racintweek
    racintweek Senior Member
    Arlington VA
    i'm putting an LS into my 91 hatch
    will performance suffer if i use the civic ecm and convert it to pgm-fi?
    i noticed the ecm plugs are not the same, so do i have to use the civic ecm?
    :unsure:
  2. brian11to1
    brian11to1 Senior Member
    Just use a 90-91 Integra ECU. Yes performance wil suffer 1. Becuase,THe civic isnt MPFI, 2. The ECU isnt designed to run a DOHC engine.
    If you are looking for an ECU (or ECM as you call it), Ill let it go for $35 shipped. Thats probably the cheapest you'll find that ECU, so, let me know. Good luck with your swap.
  3. racintweek
    Arlington VA
    so what is the difference in the 90-91 and 92 ecm/ecu's
  4. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    88-91 is OBD-0
    92-95 is OBD-1
    96-98 is OBD-2
    99-? is OBD-2B
    so a 92 ecu is obd-1
    a 90-91 ecu is obd-0
    if your car is a 92 you can get a obd-1 PR4 I belive, which will run a DOHC LS engine(which didnt come DPFI- it is the civic hatch everyone has)
    if your car is 88-91 you can get a obd-0 PR4 from a 90-91 integra and convert to MPFI.
  5. brian11to1
    Which is what he should do anyhow. ANd then he should buy the ECU I have for sale. Cuase Im a "BAT" (Broke Ass Tuner)!
