LS intake manifold
Discussion in 'General Tech and Maintenance' started by racintweek, Mar 15, 2004.
  1. racintweek
    racintweek Senior Member
    Arlington VA
    on the manifold under the throttle body there is an opening with two passages
    what the hell is it for?
    and can i disconnect the coolant hoses that go to my throttle body without complications?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    those coolant lines control the fast idle assembly. go for it.. connect them together but be prepared for a rough idle if it is cold out.
  3. pissedoffsol
    i have mine blocked off too. but the car is not run in the winter. if you live in arizona, go for it. if you live in alaska, you better not.
  4. pills_PMD
    New Albany, OH
    word.. same with me.. i dont have mine connected either, but my car is only run like 6 months out of the year.. maybe 7
  5. racintweek
    Arlington VA
    what about the opening on the manifold?
