I swapped a b18c1 into a integra ls last july. Everything works fine, vtec engages, the secondaries in the intake manifold open. The problem is that I still get a check engine code. I wired 4 things when i did the swap:
knock sensor
vtec selnoid
vtec oil pressure switch
intake manifold secondaries
What did I fail to wire when I did the swap? Am I forgetting something or is the problem not in my wiring? BTW: this is all on an obd1 system
Thanks
knock sensor
vtec selnoid
Thanks
