LS rebiuld
Discussion in 'HYBRID -> ED-EF / DA' started by vtec919si, Oct 6, 2007.
  1. vtec919si
    vtec919si New Member
    mooresville nc
    I a fresh meat to this site, so plz don't play the fresh meat game with me, I just bought a 93 integra with an LS motor, i am trying to rebliud it, the plan is to have a LS bottom end and GSR top end, i wann keep it 81mm bore, any ideas on wat pistons are the best??? also cams, wat will 403 cams work???? and wat else do i need to do to get the most power out of her, i juss wanna sit at a light next a V8 and when that thing turn green i want that v8 to see only my tail light and my tag, so HELP. thanks
  2. vtec919si
    mooresville nc
    any kinda respons would be helpfull, i juss wanna get ideas, BUT question, if i put the 403 cams, would that be too much valve lift?????? and make the vavles kiss the pistons???, guys plz and thank you
  3. SlushboxTeggy
    NJ to MA to CA
    Puncuation and grammar. But as far as pistons, you need to tell us what you want to do with it. Mild build I would say B18b pistons for turbo or CTR pistons for all motor. More extreme build then you want something forged with a compression ratio that will suit your build. The other stuff I really can't understand what your asking. And street racing is bad MMMkayyy, you give us all a bad name. Take it to a track.
  4. vtec919si
    mooresville nc
    I am trying to keep it non- turbo, i want all motor for now, the car came with a spare LS block, which i might bulid it for turbo. as far as my cams, which cams should i go with??? if i go with 403 cams, will it be tight, i really don't want my valves to kiss my pistons, and thank you for making me feel like crap about the grammer and the street racing, i have a R1 and i do take it to the track, mooresville dragstrip,
  5. SlushboxTeggy
    NJ to MA to CA
    Well this post I can read. And keep all racing at the track.
  6. vtec919si
    mooresville nc
    well since u can read it, can u answer my questions plz?
