Ls Swap Into 5th Gen Civic
Discussion in 'ECU's, Electronics, and Tuning' started by saturn_boy96, Mar 7, 2003.
  1. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    If i swap an obd1 LS motor into my obd1 civic do i need the integra wiring harness and ecu or will the stock dx wiring harness and ecu work? i am not adding vtec so i don't need the vtec wire but what other differences are threre? thanks a lot.
  2. solblu
    solblu Senior Member
    Ricer
    The dx harness and ecu will work, the map sensor plug is on your firewall and wil have to be moved to the ls map. It would be better to run a LSecu, but the DX one will work.
