Ls swapp help???
Discussion in 'Civic and del Sol - EG and EK' started by civic201, Apr 10, 2008.
  1. civic201
    civic201 New Member
    cann some one help me out and tell me what exactly that i need for a ls swap into my civic coupe
  2. BrutalB83
    Rochester Hills, MI
    Yeah, sure man. Everything you need can be found right here...
    :search:
  3. civic201
    civic201 New Member
  4. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    hah hah hah hah....hes right tho. lemme help ya get some advice. what year is it and what do u have in it right now. more than likely a d series, but its question that needs an answer
  5. HondaElite
    HondaElite senior member
    fall river.mass
    you need b series shift linkages...b series throttle cable...and the b series mounts work in the car..and so do the axles..an ls is just as easy as a 15 its just a drop in besides the shift linkage..good luck and p.m me if you need any help ive done atleast 50 of em
  6. BrutalB83
    Rochester Hills, MI
    Seriously dude, this has been covered about a million times on this site. There's even write-ups for it in the FAQ section. You could at least try searching first and then come back and ask if you have specific questions. We're not just going to spoon-feed you info that is easy as hell to find with a little searching...
  7. HondaElite
    fall river.mass
    brutal has a point...
