ls tranny or gsr tranny in gsr motor
Discussion in 'Engine Building' started by ls vtec teg, Jul 1, 2010.
  1. ls vtec teg
    ls vtec teg New Member
    hi best honda forum;)
    I did some search on this two
    I think that gsr tranny is better all the way but some poeple side that ls tranny is better in high way and other side that ls tranny are same as gsr so what do you say about it
    and one more Q
    can I use type r cams on b18b ?
    or its better to use stage 1
    for daily dive
    Thanks
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    you need to do more research.....
    gsr transmission has great gearing, much better than LS. for highway driving a LS does have slightly taller gears for better gas mileage, but the gsr is is not bad. it is the b16 and type r transmissions that have very short gearing, the gsr is in the middle. in my opinion the gsr is the best all around.
    and no you cant use vtec cams in a non vtec motor...
  3. eg6sir
    ^^ what he said
  4. ls vtec teg
    thanks alot so thats right gsr is the best
    and thanks for answer my Q s
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Depends on what you want/need. If you want good acceleration while maintaining good gas mileage, get a GSR tranny. If you want better acceleration with ok gas mileage, get a B16 or type r tranny.
  6. Magana559
    Magana559 The Warden
    fresno Ca
    or option 3
    b16 with LS 5th
  7. kjadair
    kjadair New Member
    or b16 with a ls final or gsr final or a gsr with b16 final :) oh and lsd!
