Ls tranny prob please help
demon1
whats up guys can anyone help me out with this i have an ls in my 94 ex everything is working fine except for lrd gear i try to put it in gear and it just grinds and grinds no matter how slow i put iy in there nothing helps. the one day i got it into 3rd for a second not even and it popped right back out of gear . PLEASE HELP DRIVING ME CRAZY 2ND GEAR TO 4TH GEAR HOW MUCH FUN IS THAT
Sounds like you have a bad synchro. Thats very expensive to have replaced. Unless you can do it yourself.
Adjust your clutch???? Maybe try a lighter oil or go with sythetic. Mine did the same going to third before the syn flush. It also helps to pull the shifter towards your next gear before engaging the clutch. Good luck.
hey thanks for the info guys i am going to try changing the oil today and see what happens hopefully this shit works can stand goin from 2nd to 4th it suck but will keepya posted thanks agian
