LS / turbo build
Discussion in 'Engine Building' started by Kreamm718, Mar 21, 2008.
  1. Kreamm718
    Kreamm718 kreamm809
    chonqa ville , fl
    hi people i'm new to this thing , i just bought a 94 integra ls stock
    and im looking for a goals of 290-320 hp with a budget of 4-5k . any suggestion what should i do ?
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Nice budget to start out with. Are you wanting to stick with the LS head and boost that (since LS is very boost friendly) or add a bit more of oomph right at the beginning and do an LSVTEC upgrade in order to meet your goals?
    Also, I have to ask for my own curiosity, but are you wanting to build up the bottom end at all or just go with your stock internals?
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Buy a revhard turbo kit(or something similar), larger injectors, fuel pump and engine management. Get it tuned. That right there is 5k well spent, but as far as getting 320whp, I don't think it will happen. More along the lines of 250whp or so reliably on the stock engine.
  4. Kreamm718
    Kreamm718 kreamm809
    chonqa ville , fl
    yes Luis998 im sticking with my ls head , the my plans i had in mind were to firstly built my head , port and polish it , get some cam , and sprockets , valves after qo with my block get some low compression pistons and sleeve and hot tank the block correct me if im wrong and than after boosting .
  5. Luis998
    Orlando, Florida
    It sounds like you have a very good idea of what you want thus far. Building up your head will probably be costly. I am just saying this because of personal experience. I calculated of my head, when totally built, (this is including the cost of the head) to be around $2,000 for everything I want done. This does include springs, retainers, valves, cams, cam gears...etc. etc. and a stage 2 port and polish.
    Have you looked at the prices on sleeving though? If you haven't, you may be in for a surprise. However, I do feel that going with sleeves is a very good thing in many ways, especially peace of mind.
    How about rods? You will need those if you are getting aftermarket pistons as well.
