ls v or turbo???
b1892eg
i want lsv but if i want turbo dose vtec even matter?? or should i just build it for turbo or do both? i have a 92 eg b18b and would like a high 11 low 12 daily driver! what type of a parts list and turbo should i be lookin at! new to the honda world but just tryin to learn! so any help would be thankful!!! thanks guys!
For starters, you should really do alot of research. You cant just expect to throw parts at a car with a half ass installation and make that kind of power.
It takes a lot of research. I was on the internet looking at engines and how they work 2 years before I ever made any change to my car.
Now, as far as power-wise, you can get there with a built LS or a built LS-VTEC, but the bottom line is to make that kind of power and retain the reliability of a daily driver, you will need to change the internals of the engine to handle it.
I recommend starting your research here: Turbo Information - HondaSwap Forums
You will learn alot, and maybe then you can consider starting your project.
