LS/VTEC into a DA questions...OBD1
Discussion in 'HYBRID -> ED-EF / DA' started by Somalia757, Nov 24, 2008.
  1. Somalia757
    Somalia757 SOMALIA
    VA BEACH, VA
    I am removing my b18B1 out of my DA & pulling my LS/VTEC out of my EF & putting it into my DA.I know this is a pretty straight forward affair. My main concerns are wiring up VTEC. I have no idea what to do to wire it up on the DA .I am using the same ecu that I tuned it on. But do I have to add wires for VTEC to the ecu harness?I would appreciate any help, or links on how to do this.
  2. D16SiHatch
    D16SiHatch New Member
    is your da obd0 or obd1? is the ecu you've had the engine tuned on obd0 or obd1? what vtec head are you using?
  3. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Rywire.com if you need to convert obd... it includes the vtec subharness so you simply just plug and play.
  4. D16SiHatch
    yea i could of done that too, but i was hoping to give him a more specific answer lol. ah well
  5. Andrew
    Tallahassee, FL
    He needs to give that info up for us to tell him anything.
    It was a 'blanket' shot
  6. Somalia757
    Somalia757 SOMALIA
    VA BEACH, VA
    The DA is obd1 the ls/vtec ecu I have is obd1. The head is b16a1 converted to obd1.Sorry I should have been more specific.
  7. D16SiHatch
    this is all you need then
    Rywire - Online Store
  8. yourmom556
    yourmom556 New Member
    hi i have a b18b1 in my 90 da right now buying a b16a jdm odb1 and p72 ecu thats programmed to it. my question is similar to somilias. i need a wire harness do not want to spend alot of money and have to order it online from like rywire would the b18b1 one harness work and add the vtec and know sensor or would where it plugs into the ecu not work?
