LS/VTEC......is a LS tranny a good choice?
Discussion in 'HYBRID -> EG-EK / DC' started by rsg74, Jul 14, 2005.
  1. rsg74
    rsg74 Junior Member
    Looking to buy a 92 hatch with this set up:
    block= B18A1 93 integra
    Head= B16A2 00 Si
    ECU= GSR
    Tranny= LS 95
    eagle rods
    00 Si pistons PR3
  2. formby
    formby learning in progress
    ls tranny is okay but a b16 or gsr are better.....gsr is the best out of those 3... but if you can afford it get a itr/ctr tranny.....$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  3. b204dr
    b204dr Senior Member
    Minnesota
    formby i would disagree i much better liked the si tranny over the gsr- but yes if can affordable ctr-itr with stock lsd's is wonderfull- ls is great for gas mileage tho!
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    The LS is the low man on the totum pole.. It'll work fine, but any other trans will be better.
  5. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    LS is an all around good tranny, not for 1/4 racing at all.
    I upgraded to b16 tranny, and its always above 4k no matter what gear im in... I need a 6th speed in this bitch
  6. b204dr
    Minnesota
    not to be an ass- but propperly said you would need a 6th gear- making it a 6 speed !
  7. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    I agree the LS tranny is too long for running the 1/4 mile that's what is killing me right now with my LS/VTEC setup. I would say go with the GSR cuz if you do any traveling or any long trips to the track with the B16 tranny you will be close to 5k at 80mph.
  8. b204dr
    Minnesota
    dont go 80 on the hwy and you wont have to worry lol ! - i still prefer the b16
  9. formby
    i currently have a cable b16 tranny and at 75 i'm close to 4.5k rpms.....its not that bad but the gsr has a longer final drive
  10. ef9civicgen4
    ef9civicgen4 Senior Member
    Independence MO
    ls trannys arent bad, just spend a little extra money and buy a different final drive. that will make the gears alot shorter.
  11. rsg74
    rsg74 Junior Member
    thanks for the input. I know were to look for engines but what about the tranny? Where would i get a GSR tranny or type- r tranny?
  12. 94CivicSlow
    B0ST0N
    www.car-part.com
    Or on the classifieds on any honda forums.
    (at 80mph I am exactly at 4k- Running built ls vtec with b16 hyd tranny)
  13. b204dr
    Minnesota
    www.ebay.com just make sure to buy from some one with good ratings !
  14. pissedoffsol
    that setup is kinda wack.
    using a GSR ecu on a b16 head/IM with no IAB's is counter-productive....
    IMO, if you're looking to buy this car used from someone, i'd re-think your offer. sounds like a hack-job.
    as for the tranny,
    the closer the gearing, the faster the car will accelerate.
    the longer the gearing, the slower the car will accelerate.
    LS is the longest tranny for b-series.
    you do the math.
  15. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Someone posted a video of two B16A/LS tranny EFs going at it. I was like watching old people fuck.
