LS Vtec problems please help???
tayninhnn
just bought the car, it is LS Vtec, not Vtec not knick in at any rpm. also ecu throw code 22.
i check vtec and presssure sensor wire it seen to be ok
here what i got
95 integra LS
b16a head
b18 block
ecu P28 with Skunk chiped OBD1
can any1 help to fix,
chek the engine oil, when you running out of oil the V-tec wont kick. that happens to me before and I fuck up the b16 :-(
check oil pressure, clean out the solenoid and test the vtec solenoid. make sure its live. if all else fails than the computer might not have vtec wired into the harness.
