LS/VTEC Wiring/ECU Question
Discussion in 'HYBRID -> EG-EK / DC' started by JayDeeEmDC4, May 7, 2005.
  1. JayDeeEmDC4
    JayDeeEmDC4 Member
    Im in the final stages of my ls vtec swap in my '99 teg' my car is obd2b and i just bought a obd2 - obd1 conversion harness being that im using a usdm b16a3 head and ecu for my swap. Now i was planning on cutting the leg off my stock ls ecu because im broke as shit right now!! But the question is what else do i need to converse or change (i.e. plugs / sensors) seeing that i will be obd1 now ????
    **ALL REPLIES APPRECIATED**
  2. JayDeeEmDC4
    JayDeeEmDC4 Member
    sorry for the 2 posts cpu sucks
  3. JayDeeEmDC4
    JayDeeEmDC4 Member
    ne1?
    i know someone has some info bout this situation with lsvtec's?
  4. JayDeeEmDC4
    JayDeeEmDC4 Member
    you guys were way more help 2 yrs ago ....no1 answers any questions for me nemore...cuz im a noobie?
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Calm down dude, not everyone lives on the interent, it's Mothers Day.
    Using your LS ECU is just a bad idea, and what are you talking about, cutting the leg off? Anyway, if you just want to start the motor, use the ECU that's in your car, it will run like shit, but it should start and go forward.
    Do youhave the harness for the B16A3? If so, you can use it, it will plug into your teg at the shock towers. If not, any OBD I Civic harness will work, you'll just have to add plugs as nescessary.
  6. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    cutting the leg off from the dizzy?
  7. JayDeeEmDC4
    JayDeeEmDC4 Member
    sorry i meant dizzy not ecu .... yea i wwant to use my stock dizzy , really cant afford a vtec one right now...yea i have a complete b16a3 from 95 sol (obd1) including ecu knowing that, what can i use and how can i do it? thanks for the help
  8. JayDeeEmDC4
    JayDeeEmDC4 Member
    actually dont think i have the harness, any other options?
  9. xj0hnx
    C.C.TX.
    All ready told ya, use an OBD I Civic harness, you can get it from a junkyard, fit it to the motor, try to get a vtec ones, as if not, you'll be missing plugs.
  10. JayDeeEmDC4
    JayDeeEmDC4 Member
    cant i just hard wire vtec instead or i actually need the plugs?
  11. xj0hnx
    C.C.TX.
    You have to have something to plug into the vtec solenoid right?
  12. JayDeeEmDC4
    JayDeeEmDC4 Member
    sorry dude motor is not at home i just checked and the harness IS on the motor, would you mind emailing me at JayDeeEmDC4@aol.com and giving me detailed instructions on the electrical part because I cant seem to find a how to on lsvtec electtrical anywhere ive searched every forum i can think of even lame-ass superhonda the instructions dont have to be detailed at all actually i can figure it out as long as u give me the steps...thanks man appreciated.
  13. xj0hnx
    C.C.TX.
    Detailed instructions....plug it in.
  14. JayDeeEmDC4
    JayDeeEmDC4 Member
    nevermind dude....(going elsewhere)
  15. xj0hnx
    C.C.TX.
    Is it that hard to comprehend that all you do is plug the motor in? There's detaled how to with pictures on adding wiring in the reference section, but seriously if you have the B16A3 head, and it has it's harness, you just plug it into the Integra, then add wires where nescessary.
  16. JayDeeEmDC4
    JayDeeEmDC4 Member
    thanks, sorry dude just gettin frustrated w/ swap, not your fault
